T
Toneyz
Has anyone installed the above is it any good?
Nothing better to add than bad spelling.Has anyone installed the above is it any good?
Thanks for the critique seen what you posted on the leaflet thinking using more in a bollard.Yes, I've installed several.
Mainly for joining SWA with 20 or 20s glands, using one of the metal earthing plates with 3x 20mm holes, that fit in the lid, found it satisfactory.
You can also fit the glands into a flat side wall, again with a metal earth plate available, but I found that quite tricky and only ever did that once.
