Discuss WAGO IP68 Waterproof Capsule in the Electrical Tools and Products area at ElectriciansForums.net
Yes, I've installed several.
Mainly for joining SWA with 20 or 20s glands, using one of the metal earthing plates with 3x 20mm holes, that fit in the lid, found it satisfactory.
You can also fit the glands into a flat side wall, again with a metal earth plate available, but I found that quite tricky and only ever did that once.
Thanks for the critique seen what you posted on the leaflet thinking using more in a bollard.
Reply to WAGO IP68 Waterproof Capsule in the Electrical Tools and Products area at ElectriciansForums.net
