mira advance 9.5kw expensive but the best, keeps the same temp even when theres a change in water pressure.
The best shower is the next door neighbours
No install and set up fees
Its cheap on your electric bill
It doesn't impact on your water costs
Maintenance free
Usually free replacement when faulty
Never causes leaks through your kitchen ceiling
Cleaning carried out by others
If you cant be tempted by that,try the MX inspiration range
I have fitted quite a few and they are reasonably priced and have never been a problem
Maintenance free
Like it mate
I actually wanted to start a new post, but could not find how on this forum.
anyway, I have a broken Triton Opal.
I know I can change with either another Opal, or a Martinique. Both do not need me to replace the connections:
- right side electrical cables connetion
- bottom right side piping connection
But looking at other brands, which models can I buy to replace my Opal, with same connections ?
Thank you
Shivy
