H
holychihuahua
Two consumer units and meters. One pair for a flat above a shop and the other set for the shop. The armoured cable rising diagonaly above the consumer unit ajacent to the building electric supply feeds the the shop meter and consumer unit in an other basement room.
Well, that CU with two RCDs and all those missing blanks, doesn’t look good at all.
Neither does the other one, with those ill fitting MCBs.
It makes me laugh when spark come on the forums and asking about the jobs they do are doing or going .
Say your other half comes in with a dress and its tucked in there nickers
And you about to go out would you say
You look nice or would you say you are only half dressed .its a s&&t job.
Rather than use a new bit of earth cable because the old one is 6 inches too short they just grab a bit of 15a connector and ‘ add a bit ‘
Nice work
Nice work
The armoured cable is a roller coaster run. There is plenty length to connect an uninterupted earth. The cable is salvaged three phase where the yellow has been used as an earth.They were too lazy to cut the sheath back .
