It’s outside - the banjo bends up - never had a problem fitting a banjo on these ones
I didn't think there would be enough thread inside a wiska box to get two locknuts and a banjo on.
Or have you got the banjo fitted between the plastic and a single locknut? If so I thought this was considered unacceptable due to the connection not staying right as plastic moves with changes in rmeperature.
2 types of wiska boxes in use - one has double locknut (banjo in the middle) just enough thread to get it nice and tight.
The other has a piranha nut as not enough thread showing - thanks
