Bulb has a smart meter experimental tariff:
1600 -1900 hrs (Dinner cooking time) 29.75p per kWh
2300-0700 hrs (overnight) 7.45p per kWh
other times 12.19p per kWh.
Standing charge 20.44p per day.
This is in SE London, other areas may vary slightly.
which appears to agree with my prediction in post #10. cheap leccy when you're not using much (if any); expensive leccy when you need to use more.
So they cannot change the tariff 'at will', only within the agreed times. Electricity costs vary throughout the day so if that is the tariff you choose then so be it. I choose to have a fixed tariff therefore I pay the same for every kWh I use until the end of my contract. Why choose a tariff with a cheap period when you know you're not going to be using it?
[automerge]1567010219[/automerge]
Sion1234,
Jim Cartledge,
