These two are proper neat.....10 yards apart, one a grinder, one a welder.
This was a builders extension, I cut the plug off also then watched from afar.
I was once on a small domestic site where
A builder supplied the decorators with a 240v real lead of which the plug top had no top.
The painter plugged it straight in getting a wicked shock , then his mate tried to unplug it while it was still live getting himself a wicked bolt...
I kid you not , this is absolutely true
Soon as I saw what had happened I cut the plug top straight off
You'd have been better off cutting their hands off, for their own good.
[automerge]1567100131[/automerge]
N
Ok -Oversized cable , bound and crushed.
(and may years worth of other bad habits)
Honest Joe photo. (non ideal View attachment 51738photography)
Not a bad effort, is this going to turn i to an "I can wire a plug me" thread?
[automerge]1567100354[/automerge]
N (blue) L (brown)
Look I know I'm a short course shyster but I worked that one out already.
This was on the charging lead of a patient lifting hoist. It wasn't charging! The original moulded plug had been ripped off and this was fitted by the handyman.:confused:
[automerge]1567111571[/automerge]
And here's another one, same care home a few months later.
[automerge]1567111858[/automerge]
Went to check a bed at another care home, wasn't working......
...And that's why your pliers have a handy wire stripping notch in the cutters.
Isolated power, unplugged THEN cut the plug top off.
re, the OP photo.... that neutral wire is way too long. Should be roughly halfway between the length of the earth and live.
I bet they stripped the flex back and were using it again on bare wires in no time.
I've seen an extension lead like that before. A old farmer had one for his generator for when the power went out.
He would plug one end into the genny, the other into a socket in his house, thus giving him power.
Yes, using a widowmaker for a genny is commonplace, but as an extension - not very. Though years ago I spotted one running the till in the local chemist - no-one seemed at all bothered when I mentioned it.
Hopefully not "commonplace", although indeed you do see them from time to time.
Most people are completely ignorant of the dangers of their widowmaker leads, but equally most will listen and learn if you take the time out to explain.
I think it's because the 13A plugtop is a familiar everyday item whereas the 16A ceeform isn't, that they don't immediately see anything wrong with the example I've pictured here, but if you suggest two 13A plugtops cabled together, the appreciation of danger usually registers with a layman.
