Discuss Little Things Done Well in the UK Electrical Forum area at ElectriciansForums.net
GBDamo
As title, show us your little uns.
Just remember the smaller it is the less chance of non-conformances.
PA Testing is so boring the only failure I've had is this plug top that was poorly wired and flex not secured.
Should have done a video to go with it, YouTube it and make millions of £££s.
It is indeed boring...and why are the stickers so expensive? They ought to be cheaper now you don't need a "Next test date" section.
terrible. the flex should have been twisted so that the N (blue) was on the left instead of on top of the L (brown).:eek::eek::eek:
What do they expect for £1.20 per item, the moon on a stick?
[automerge]1567095400[/automerge]
Oh dear, you've said PAT - Pete999 won't be happy :):)
At least it was only "PA Testing" and not "PAT Testing" that would've sent him to an early(ish) grave.
? It's supposed to have a top, wondered why i kept getting a jolt every time i plugged it in.
[automerge]1567095602[/automerge]
That's ok I put them in the plug bottom, or is it plug top bottom.
Snigger.....plug bottom....snigger
I was once on a small domestic site where
A builder supplied the decorators with a 240v real lead of which the plug top had no top.
The painter plugged it straight in getting a wicked shock , then his mate tried to unplug it while it was still live getting himself a wicked bolt...
I kid you not , this is absolutely true
Soon as I saw what had happened I cut the plug top straight off
You'd have been better off cutting their hands off, for their own good.
[automerge]1567100131[/automerge]
N
Ok -Oversized cable , bound and crushed.
(and may years worth of other bad habits)
Honest Joe photo. (non ideal View attachment 51738photography)
Not a bad effort, is this going to turn i to an "I can wire a plug me" thread?
[automerge]1567100354[/automerge]
N (blue) L (brown)
Look I know I'm a short course shyster but I worked that one out already.
Reply to Little Things Done Well in the UK Electrical Forum area at ElectriciansForums.net
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
Hi, I'm completely rewiring a 9 bed 3 storey HMO in Jan, The fire detection required is just some linked lithium detectors in the...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
