Are you an electrician Colorado
[automerge]1567367876[/automerge]
Do you think you got the polarity crossed when you changed other outlets?
I am not an electrician. I do have experience with this and running basic outlets, wiring, etc. from the Army.
Polarity isn't crossed. Somehow the problem originated upstream from the outlets I was working on. I now have a "jumper" cable hooked up between outlet 1 & 2, as well as the original wiring hooked up as normal and it works now through the whole circuit.
You made the statement that you twisted all the whites and pigtailed it to what
[automerge]1567369951[/automerge]
Colorado is it possible that you have your switch leg crossed ?
