E
erwin1991c
What output current will I get if I have an input voltage of 700 volts at 1 amps and if I step the voltage down to 230 volts what would be the max amps I'll get.
Erin to start with what are you wanting to put 700 volts in what to get 1amp I guess there’s not enough information
Didn't think about that yet. 700 volts at 1 amp is single phase using a generator. I want single phase 230 volts. I want to know what max amps I'll get if I want to step down to 230 volts. Please advise
Is it a 3 phase transformer and what’s the KVA rating of the transformer
What is your normal voltage
[automerge]1572310691[/automerge]
So if you start your generator you get 700 volts
[automerge]1572310869[/automerge]
If you want to step down to 230 volts you will need a transformer
[automerge]1572311028[/automerge]
I’m curious where did you get a generator that puts out 700 volts
I'll be connecting 100 motors in series (model of motor is 775 motor). All I know is that the winding of the month can handle around 1 amp current. Assuming 1 amp and 700 volts if I want to use a transformer to step it down to 230 volts what would be the max amps I'll get.
Hi - if it was a perfect transformer with no losses its a simple calculation 700/235 Amps. As this transformer doesn’t exist you’ll get a bit less.
