@Andy78: Big thanks, I needed that. How much does a tester like that cost?
That's a multifunction tester, also known as an installation tester, that performs all the tests required to verify safety.
That particular model is about £500 new. It's quite a basic model compared to some. Across all brands they range from about £400 to over £1000 depending on what features are included.
You can get dedicated RCD testers which are a bit cheaper.
[/QUOTE]
Might just get one. Are the cheap ones good? How will the tester tolerate 120 volts and line-line 230 volts?
You would have to look at the details in the specs or contact the seller/manufacturer to find out.
I think some of them do work on those kind of voltages but can't say for certain.
@Cookie you seem to have a good degree of knowledge on this stuff do you not use Multi function testers stateside? ?
I can only go on what I've seen on here and the Web, but they don't seem to put as much emphasis on testing and then evaluating the test results as we do over here. Happy to be corrected though.
I did suspect that.....just made me more curious as to how they verify installations over there?.....
There is no testing requirements in the states, in fact when I bring it up on US forums it does not go all too well.
Multi meter, clamp on amp meter and a pigtail socket with a bulb in it. Circuit tracer as well.
I know how they work, they use a differential coil to sum zero sequence currents. The thing is I don't exactly get how eletrmechanical RCDs respond faster to high current ground fault vs low current ground faults.
It might take the US time to catch up with UK on testing as we do.
Reading a US forum would really be interesting
How long ago did the UK actually fill in test certificates on every job?
Even I can remember a lamp holder with 2 single cables for voltage testing and an actual doorbell for continuity testing.
