Would any of this lot be any use to you?
LINK!!
I do a bit of work at our local church. Had the same problem with spotlights that I could luckily teach from the balcony.
The biggest problem was “old joe” the caretaker of the past would change the lamps, and put the faulty ones back in the store room beside the new ones.
7 boxes of lamps and only 1 good one found.
ive suggested the get LED ones into stock.
Another balcony had lights that were tripping their mcb. Due to the balcony not being used for safety reasons, I disconnected the part of the circuit going up there.
a big problem with churches I find is the location of the db is in the most awkward corner they can find.... and of course, you can’t swear in a church.
How do they change the lamps in the lights if you can't get at them with a ladder?
I would reckon the time the lights were fitted, they didn’t have H+S telling you not to use a ladder
I've used one of these before, simple to erect and move around and it fits in a medium sized van
That's what she said.
  • Funny
Do they tell us not to use ladders now?
Now, @davesparks we all know what I meant. and as mentioned on a previous post..... 3 points of contact on the ladder..... only to be used for access and not working from.
Its all down to the heights involved and common sense.
Yes, 3 points of contact, but as taught on the last working at height I did your knees can be points of contact.
They shouldn't be used for long periods of working, but for short duration tasks such as changing lamps and fault finding I see no reason not to work from a ladder of it's the only access equipment which sensibly fits the task.
The suggestions in this thread about having scaffold built or using powered access inside a church seem ridiculous to my mind.
[automerge]1583956989[/automerge]
Liking the 3rd leg (she said) for stability. Not sure about being enclosed in the cage though - bit restrictive?
That's not much different to the basket on a tallescope.
Reactions: GBDamo
I use ladders quite regularly. As long as they're footed and common sense is used, no problem.
I did use scaffold in a church last year for changing some lamps to led corns. They were central (no walls) and we just shifted the pews to suit.
In one old church I installed a winch in the attic for a multi lamp fitting.
EDIT. The pews were old, fixed and couldn't be seperated.
Had to Google that Dave. Useful bit of kit, bet they're not cheap.
That's OK if the pews aren't fixed
[automerge]1583957680[/automerge]
A tallescope? You'll find one in pretty much every theatre, they're pretty much a standard piece of access equipment.
They're a bit unnerving until you get used to them, they can be a bit wobbly at full extension!
in a church, surely god will protect you?
on a more serious note, never attempt to do a job without the right equipment.
chance it with a ladder, you can get away with it for years but one day it WILL get you.
the church will not provide for you whilst you lie crippled.
Reactions: Jim_e_Jib
Church floors don't tend to be very accommodating if you land on one at speed from a great height.
Invariably better than factories, I'll tell ya.
HappyHippyDad
Supporter
Gloucestershire
Working at height?
HappyHippyDad,
Gavin John Hyde,
