C
ChrisGW
Hi, Could someone tell me what make this is? And where to purchase. Thanks
It is Lewden agreed sometimes called control gear direct from denmans it's a weather proof enclosure used as a consumer unit
Im going to be pedantic... sorry
Yes its a Lewden consumer unit (CU) as apposed to a CCU as you call it in the thread title.... which is a Cooker Control Unit
Im not perfect myself, normally calling a carbon monoxide detector a Co2 alarm... which is a different gas altogether.
Except in any C&G exam or coursework, a CU is always referred to as a CCU (consumers control unit) these days.
I think CU and CCU are both 'correct' terminology, it's just that CCU tends to be the term used by the newly qualified, tutors or those who do design/drawing work.
I always got taught a consumers control unit was a panel board/section board/busbar chamber assembly etc with it being a MCCU if it was the only or main one.
A distribution board or consumer unit was generally associated with final circuits.
It’s maybe a regional thing. I was just told (time and again) that a consumer unit was domestic board.... for the homeowner, or consumer, to use.
a distribution board was more industrial... SP or 3P and could serve other sub main distribution boards
WRTYUIOP[]Qloppppolp[;o B-- sw
fiwc
[automerge]1594998624[/automerge]
soz.was wiping keyboard.
