Side note: If/when an electrician is on site, please ask him to install a blank in that consumer unit to fill the gap that's letting that main switch push right. Can't see what make it is from the thumbnail but a standard metal blank should fit...
Well spotted!
Small size of image is not helping much :(
This makes it look easy:
It looks easy, but then you navigate through an endless process of 'press 1 if it was installed on a wet tuesday.....' and at the end of all that get rewarded with a recorded message saying that this call centre is closed due to all staff temporarily working in the emergency call centre due to a high volume of emergencies.
It's no wonder people give up and pull cutout fuses themselves!
