T
Tunni
Hi all, I'm looking to shift the wiring of an exceptionally awkwardly placed old fuse board to a shiny new 18th ed compliant board a few metres away. As all the wiring will still have to come to the new board from the old location, literally at the back of a 2m deep cupboard and directly under the bottom but 1 stair I'm thinking I'm going to need a fireproof enclosure and some lovely sure connections.
With that in mind I was thinking of using din rail mounted terminal blocks, my only concern with this is that the earth terminals all secure with electrical contact to the din rail. To my mind that will make any R1+R2 reading a nonsense as there will be parallel paths to all circuits regardless of the connection at the consumer unit.
With this is mind should I just bin the idea of using the earth terminals and opt instead for a generic beige terminal? I've not had much to do with this panel wiring kit so anyone out there who does or has an informed suggestion I'm all ears.
Yes I know I'll need a switch fuse for the tails etc...
