I'm a hundred plus miles away from mine so trying to visualise.... bigger than you'd think, I'd say in the 24-28mm area comfortably
25mm according to screwfix Q&A
Measuring the one I have gives 25.86m
So you need a 26mm af socket.
Just tried a 25mm socket, and it won't go on, but 26 does.
The higher quality rods are threaded to UNC-2A ,and that would be an imperial 1 1/8" A/F,but as they are not made as a fastener,they can use any combination of size/type.
A 26mm socket is included in larger sets.to pickup imperial sizes,between the standard metric increments.
