N
Neil2021
Hi
Would really appreciate some advice on this as I have pretty limited electrical knowledge
I live in a fairly new build home with 3 floors and the fuse box can either turn off all the plug sockets on the ground floor or turn off all the plug sockets on the 2nd and 3rd floor in every room
I basically want to be able to switch off sockets or power room by room, basically so I can turn the kids electric off at night to stop them staying up half the night ? without it affecting the other rooms
I've used WiFi plugs (not sockets) but these can be easily overridden or just unplugged, so not much use
What would be the easiest and cheapest way to do this, would it require any kind of rewiring or a new fuse box or circuit breaker?, I have looked at WiFi sockets but most of these can still be switched on and off manually, I did find a lightwave socket that can be controlled by RF and has a child lock but this would need installation and don't know how reliable these would be
Thanks in advance
Without doing some research on this (it's a very unusual request)... I'd suggest that the easiest way to achieve what you want is the Lightwave RF option with child lock. Any 'hard wiring' would be far more disruptive and would need very careful thought and planning... due to a whole host of possible issues.
Reactions: Neil2021
Would be quite invasive to achieve what you need as the install was not deigned to do this.
I know a few customers whom I have installed a network for turn the WIFI off over night using the setting in the router to stop kids playing games all night.
It appears now that without WIFI nout works.
Reactions: Neil2021
Would it not be easier to remove all equipment out of their rooms. Splitting the circuits will be a big job.
Thanks, I did try and research online but not a lot of information out there and also asked an electrician, who said to just get a new fuse box but didn't think it would be as simple as that
Would be quite invasive to achieve what you need as the install was not deigned to do when it was designed.
Yeah I imagine it would of needed to be wired up this way from the start, I can turn their WiFi off at night but they can get round that by using mobile data and tethering
You may need a new fuse board to house the additional MCBs for the separated circuit. but the wiring under the floor will need re-configuring.
The only time I have done installs like this are on large mansions.
Reactions: Neil2021
Yeah it's looking like it will be a lot more complex that I thought, I could take everything out of their room every night but just means unplugging and plugging everything in every day
Deduct the cost from their pocket money, they will comply eventually.
Then take their mobiles off them at night until they learn. How old are these kids?
Reactions: Neil2021
Done that before but means doing it every night, older ones are 15 and 17 but got younger ones aswell, but there not an issue, yet ?
You can install remotely switched socket outlets at each point.
So in each bedroom outlet (turn the whole power for the house off first!!!!) remove the existing outlets and fit the replacements (Whatever cables were in L must go in the new L, whatever cables were in N must go in the new N, and whatever cables were in E must go in the new E) - much better to get an electrician to do it.
Then you can download an app to your phone and configure each socket outlet to operate from your phone app.
BG do one, type BG 922HC for a double socket outlet - around £16/17 each I think (edit £15 at screwfix)
You will need to stick to the one make usually, but there are several around.
there are a couple of issues - firstly the cost, and secondly if your kids are smart they could configure it all themselves as well.
Some example instructions attached
I guess you could split that ring into two radials... such that the kids bedroom is at the end of one of the radials... then on the radial that feeds the kids room, find the last socket before it enters that room and replace it with a key switch of some sort.
Reactions: Neil2021
Alternatively put a pay as you go meter in their rooms.
...and secondly if your kids are smart they could configure it all themselves as well.
Won't they just unplug it and plug something else in ? or have I missed something ?
Or... you could covert their room into a faraday cage... thus blocking all internet signal... that might inhibit activity ?
Or just unplug the internet router ??
Or better still... install a peddle powered generator so that they have to generate all their electricity themselves ??
That would also give them some exercise whilst simultaneously saving the planet !!
The OP is a member of the forum now, if he unplugs the router won't be able to join in with us all.
Not me being too personal here, but I think you need to engage with your kids a bit more. Rules, boundaries & regulations. Speaking from my experiences, if you can't agree on simple house rules at 15-17 years old, your going to visit a whole new world of hurt as they get older, and they start making up the rules for you to follow.
I think doing what you are proposing, is going to make them feel like they'll do other things, just to challenge your time reducing authority, you have left.
Millions of parents are in the same predicament but do not resort to expensive solutions, although it may seem harsh at first you really need to take control here and stop the empty threats, removing laptops phones and other devices only works if they actually miss them, getting caught at night and giving them back next day is not punishment, set a punishment of 1 week without any access day or night to such and any homework that needs computer access will be done in the same room as you at a reasonable hour.
It's amazing how fast kids come into line when they cannot txt their mates or send them pics and other fun messaging stuff, removing the thing they cannot go without is the best way to stop them abusing your rules even if the rules they break have no link to what you confiscate.
Controlling plug sockets room by room
Neil2021,
sheena,
