Discuss Domestic kitchens in the UK Electrical Forum area at ElectriciansForums.net
When wiring a domestic kitchen is ok to supply integrated appliances from 32A/ 2.5mm ring via 20A D.P. Multi grid Switches , using 2.5mm on out going side of switches to a 1 gang socket or spur ?
That’s how a lot of new builds are done. Although I think there’s a few on here who don’t like using 20A DP switches protected by a 32A ocpd.
Are you putting in a ring solely for the integrated appliances?
Some appliance manufacturers specify a 16a over current device. So if you are strictly following the M.I then putting the appliance directly on a 32a ring is not correct.
of course the appliance will work hardwired directly to the 32a ring and I have done this on occasion but technically it’s not correct unless fuses down to the correct rating
A grid switch set up is totally compliant. It’s just spurs off an rfc.... although branched off very close together within the same box.
As with any infused spur, you can feed a double socket... but not usually done in a kitchen environment... single sockets only.
The above is for a “standard” rfc 32A OCPD
Reply to Domestic kitchens in the UK Electrical Forum area at ElectriciansForums.net
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
UK Strange
I am decorating our bedroom which only has 1 double socket in it. We have been using multiple gang sockets which are untidy and a trip risk, so I...
