M
MichiganMan
My box truck has interior lighting in the box and its wired directly to the fuse box (blue wire at bottom of pic). The interior lights are also connected to the front marker lights somehow. After months of it being fine, it went haywire last night and now they're shorting out the ignition and dashboard. I pulled the fuse (that I'm pointing at in the pic) to fix the problem. But now 2 clearance lights aren't working (3 are?) and I hav no in box lights.
It's a 15 amp fuse, 12g wire, 2 bar LED lamps, a center led lamp, 7 running lights(clearance lights
So do I hav to much happening on the circuit now and it needs more ground? All I did was tie into the ceiling light and added 2 bar lights and a switch. Now the truck dash is goin haywire... i couldn't shut it off after I took the key out. I turned the headlight knob and it finally quit with the speedometer needle goin crazy. Please help. Thx
