I'm assuming the one we have fitted doesn't have a cut out? Excuse my ignorance but what's a MET?Yea I would they’ll put you a nice new Tns cutout for you & the correct MET, hopefully
mental earth terminal if you git it wrong when testing.I'm assuming the one we have fitted doesn't have a cut out? Excuse my ignorance but what's a MET?
Looks like a pipe to me could be gas and redundant hopefully.What is the thing poking out from under the skirting board on the right? Thought it was a pipe at first but not sure.
Also it looks like thin red wire not far from it on the floor is it just an offcut?
I wondered the same.Looking at that cutout, there is a possibility that it has a fused neutral.
Ring WPD back up and tell them you want a safety check because you are worried.
Sounds like they are looking for a contribution to fix a problem that is theirs to fix. The 2 DNO's I regularly speak to would have more than likely had that on a 2 hour response once the condition of the earth is mentioned and not made some feeble comment to try and extract £160So I raised this with Western Power and got a phone call from someone who said it wasn't an electricians place to tell them if their equipment needed changing and it was possible the house was provided without an earth and if we wanted one it would be £160.00.
