Dali748
Hi,
I'm doing some research to see if I'll be able to add an electric 240V/30A washer/dryer combo to my condo. Please see attached photos, I have a 30A subpanel in my condo unit; would it be possible to add a larger panel with more spaces and run this washer/dryer combo or is the 30A subpanel just not enough power?
If not enough power, would it be possible to increase the 30A breaker in the basement to a 60A or 100A breaker this way this would then feed to the larger panel that is installed in my condo unit?
Thank you!
Hi,
Thank you!
By code you need a 20 amp single pole breaker with a GFCI receptacle for your washer and a 30 amp double pole breaker for your dryer. According to the 2020 NEC the dryer also has to be GFCI also
Reactions: Dali748
Thank you for the reply. After further looking into this it seems like I only have 30amps coming to my panel in my condo. Seeing if I can install a washer/dryer combo that's gas this way I only need 120V.
Well good deal and good luck with your project
Reactions: Dali748
Email
Time zone
Last seen
30A Subpanel - Larger Panel For Washer/Dryer Combo?
Electrical Appliances & Whitegoods Forum
Dali748,
Megawatt,
