Something else to consider ...
What about a situation where one brand really is the same article as another but with different screen printing ?
Depends on your due diligence and how covered you want your arse as I'd want concrete certainty that the badge is the only difference before I start mixing switchgear
I would only use the scenario with Schneider for replacements in Merlin Gerin or Square D boards where the manufacturer confirms compatibility.
I would only use with scenario with Schneider for replacements in Merlin Gerin or Square D boards where the manufacturer confirms compatibility.
Are there documented cases of the dangers that using different makes pose?.
I ask as I have not had personal experience of this issue. From what I,ve read so far the 2 areas of concern appear to be....
1) possibility of overheating due to incompatible buzzbars
2) the electronics and magnetism of different mcb types interfering with operation of each other
I still can,t figure out how both issues can,t be addressed by physical distancing of the different types in the same CU.Over here we use a 2 row D.B. Having one make on the top row and another on the bottom row has never led to any issues in my experience.
The situation I describe would be unusual ( and unprofessional in my view).
But occasionally circumstances require it.
