dprance
Hi.
I have recently moved into a house and I'm trying to install a Ring Hardwired Doorbell at the property. I've had a look at the Ring instructions and at the chime box but I'm completely lost as to which wires to by pass in order to give constant power to the door bell. I have a separate plug in Chime.
Any help is very much appreciated.
Hi.
That chime looks vintage to me because of the mercury tilt switch, 11/2 Volt nomenclature in the battery bay and quality of the Bakelite. If you dispose of it sometime contact Lucien Nunes because he may want it for his museum.
Another one!
Only difference is your wires are old red and black colours instead of the newer brown and blue.
Throw the Ring instructions in the bin.
Legend cheers Brain.
So just to check (before I risk frazzling myself):
Two Red into one of the connectors
Two Black into the other
Keep the supplied fuse wire (?) connected between the two.
See the pic. Cheers
