S
SparkMuffin
Hey all, looking for a bit of industrial electrical advice, I'm kind of stuck between a rock and a hard place at the moment, the company I work for are pressuring me to work on HV (11KV) against my will.
They put me through a 4 day AP (approved person HV) course and as I was the only person who didn't deliberately fail I have now been lumbered with all the building substation switching and permits etc. I'm switching RMU's under duress however they have a new large piece of HV equipment that has been connected to the HV supply (by a contractor not me!) that they want me to energize. This piece of equipment has been constructed abroad clearly to the lowest tender and in my mind is totally unsafe (exposed HV and LV in the same area ( a couple of feet apart, the LV is to be handled and terminated by people on a regular basses as they are essentially DC power leads for powering units under test) with access to this same area for servicing / repair to the electronics). The access to the area is via a hatch that has an interlock that has yet to be wired up, this will operate a HV shunt trip however the power for this is on a separate supply that if lost will make the interlock inoperable, if it does operate I'm not sure if there might be any residual voltage left on the incoming supply unless the RMU shunt trip earths the cables when it fires. Previous units have had all the nasty HV stuff in a separate sealed of area well away from anything low voltage, I have no issues with those.
I'm currently refusing to operate the isolator to this unit until the company get a qualified and competent HV engineer to sign it off as being safe.
I know I'm personally liable if anything goes wrong, I would put my notice in in a heartbeat but am too old and too stupid to get another job, I know if I power something up that I think is not safe I will rightly go to prison, hope this makes sense, haven't had a whole lot of sleep lately, what are peoples thoughts?
