you are probably limited by the contract you are on rather than any actual limitations, so I would think you could ask them for a faster rate.
The BT contract is the daughter's. BT is her employer (although she work's for the Police), and the broadband comes free with the job. I've no idea what limitations might be in place, but I'll mention it to her.
You've all given me plenty of options to think about. Seems that fibre is good, but cable, with a network switch near the middle, will also work.
One problem with a single piece of pre terminated fibre is that it will have to pass through two 600mm thick solid stone boundary walls between properties. These walls have 20mm round PVC conduit through them that was fitted when the renovations were done, and have Cat5E, bell wire, and 2 pair 'phone cable passing through them. Plenty of room for more Cat5E or 6, but those optical plugs are going to be a problem.
45m of Cat5E/6 followed by 100m of fibre is possible, or is that pointless?
As far as the trench is concerned (still another 30m to dig), I've ordered some green 65mm outside/50mm inside smooth bored twinwall duct to go in with the SWA and 20mm water pipe, so that kicks the final decision down the road for a week or two.
10mm2 3C for the SWA turns out to be just too small. Considered 6mm2 5C doubled up, which is just adequate, but will probably go with 16mm2 3C and have done with it. Costs another £100 on top of the 6mm2, but that's minor compared to what the whole project is costing.
There are plenty of cheap fibre termination kits out there with good reviews so not beyond a DIY termination job with the wealth of knowledge on youtube for an experienced electrician IMO based my experience.
Personally I taught myself fibre termination and polishing from books and videos ( pre youtube ) about 25 - 30 years ago although cheap termination kits were not available back then and the kit I still have cost close to £1000 but paid for itself after 2 - 3 jobs when I was quoted just over £500 to terminate 2 fibre cores (4 ends) for one job I looked into the options and decided I could do it myself with the right kit. These days the fibre terminations are a lot different and some don't even need polishing after termination. Even buying a few extra terminations to practice with it's a good option to look at and makes it easier to do the full run in fibre
If you get the "single fibre" style of unit then a single / simplex LC type of connector will fit through something like a 10-12mm hole, though really for protection you should put it in a bit of tube, etc, and feed it through with any other cables, etc, that are going in at the same time.
Having some cat5/6 cable then the rest in fibre is not pointless, while you could do the rest in copper the fibre still has the electrical isolation aspect but it means you need the powered switch at the point, going all-fibre avoids the need for some network kit hidden in an outdoor box or whatever.
@UNG suggestion of getting the tools to do it is maybe not worth while for just one cable, but you might find someone who would do it for you ate a sane price if asking around or you might find local work you could charge for to make it pay.
When I said cheap I meant cheap Optical Fiber Tool Kit Cold Connection tool Optical Fiber Stripping Cleaver for SUMITOMO with 36000 Cleaves and Fiber Optic Drop Cable Fiber Stripper CFS-2 Double Port Hole - - Amazon.com - https://www.amazon.com/Optical-Connection-Stripping-SUMITOMO-Stripper/dp/B01GLRWXDC/ref=sr_1_6?keywords=Fiber+Termination+Kit&qid=1661238435&sr=8-6
It has good reviews and I wouldn't dismiss it as not a viable option
When I spent £1000 25 - 30 years ago it was a totally different market with a lot of voodoo about fibre termination around, the tooling, terminations and termination methods have changed a lot over the years making home termination a lot easier and more viable now.
That is cheap, I was thinking of these sort of machines:
Might be a case of not trying monomode fibre with the cheaper kits though in terms of alignment, etc, but worth some experimenting with a short fibre as 1m (test) or 150m (final) of fibre won't make much difference to a SFP combination that can do 2-10km!
Very interesting. I wasn't aware that such kit was available at that kind of price, or that any attempt at DIY termination was even possible. Bares more than a passing resemblance to the kit used by the Openreach technician when he connected the fibre to property five years ago.
On the other hand, daughter in question has a lot of contacts inside Openreach.
I would be inclined to try and get a pre-assembled LC simplex cable in and use the single fibre media converter that @timhoward found. If a cable connector gets damaged then look at a DIY replacement connector effort.
If she has connections then it might be easy to get help to fix any damage. In recent years/decades I have not seen folks actually put on connectors, they have a bag of "tails" with pre-terminated connectors and a short lead and then use one of the fancy automated fusion splicing machines to join on to the main fibre run.
So with all the options available running a fibre for the data isn't the problem it started out being
Except when it comes to getting round corners in containment. That stuff likes to have quite a bit more room where bend radius is concerned.
Most fibre is fine for any normal bend radius, in fact far easier than almost any SWA as a few cm is fine.
What they are not forgiving of is being pulled tight against a hard corner!
Any fiber I've dealt with needed a much greater bend radius than an equivalent SWA would. A fibre cable of similar OD to CAT6 would comfortably bend on a radius similar to that required by 4mm SWA.
Edit: I've just looked to see what the actual requirements are and it appears as though fiber requires a radius of 10D, which increases to 20D when being pulled under tension.
I was going to say 10-20 diameter is the figure I remember, and as typically the diameter is around 2-4mm that is not so difficult to meet (other than on a corner, etc).
25mm swept bends are fine, but angle boxes, tees etc are not. Unless it's a straight run I wouldn't attempt anything smaller. Of course this may all be irrelevant to the OP's situation.
Would a 5G mobile internet signal be of any use?
Seemingly you can land a plane and shave someone with a robot arm on the top of a mountain according to Kevin Bacon
