M
Ma12967
Hello,
I have emergency lights that require a ctu. They are a mixture of non maintained and maintained. Do I need a contactor and a ctu? If so how do I go about wiring this?
what is a ctu??
ah, I would know that as an emergency lighting test switch or secret key switch.
If they are all off one supply at the CU then a CTU would be the easiest.
That’s what I was thinking? What do I do with the ctu? Take a feed from mcb to ctu then put cable going out to lights into ctu aswell? Never installed one before 🙃 been stuck house bashing for too long!
That is certainly one option with a wago for the neutral.
Feed from mcb/rcbo to ctu then to light feed.
You can't do that with non maintained fittings they must operate upon failure of the local general lighting.
