B
bill5498
have a GFI outlet. I have not shut tge electricity off to the wires, they were live. I have the white neutral wire hooked up to the outlet. I have the ground wire hooked to the outlet. I a small zap when I touched the bare metal of the pliers and bare hot black wire. With the black hot wire not on the outlet I used a multimeter to see what was live and what wasn't. Using the leads, I touched the black hot that was not attached to the outlet and with the other lead, touched the white neutral wire that is attached to the outlet and the multimeter showed 120.03 volts. Now, I again touch the lead to the black hot wire that is still not attracted to the outlet and put the other lead onto the bare ground wire and the multimeter showed 2.3 volts. Is this normal?
