K
Kamikaze
I bought a fux capacitor off ebay and installed it in my transit as instructed in the manual a couple of days ago, but after I keyed in my destination date and hit the required speed limit (i.e.= 88 mph) I was still unable to travel back in time. Checked all the measuring equipment, the level of plutonium was adequate and the pure kinetic energy dumped at the point of climax was indeed 1.21 jiggawatts. Just can't figure out what the problem is. Please help! :o
I wish my transit could do 88MPH, the dual mass flywheel usually collapses before then!
basic problem the fact that the plutonium will not fuse at the temperature generated by unleaded petrol. you need to fill your tank with Avgas100+ octane , the stuff we put in our Spitfires to defeat the Hun in 1940.
How the fux did you get a Transit to do 88mph in the first place? Typical Ford Speedo - it's out by at least 10%. I reckon you were only doing 79.2mph anyway.
Just been out there again and done some tinkering. Telectrix, I did try the solution you posted above to no avail and received some mild burns in the process - I'm fairly sure it fried most of the electronics in my immediate vicinity. I double checked the Flux cap and noticed it did not have a British kite mark and had "made in North Korea" stamped on the bottom. I can't believe I missed that. I do think the problem is with poorly made shielding around the flux cap causing the Flux Cap to leak charge. Do you have any recommendations for materials to use as insulation? It's going to be a while before the next lightning strike so I'll have some time to work on this
as alexander the meerkat says "Simple". next time you are working on an old building, rip out some luvverly asbestos ( blue is best) and use this to make a shield. don't forget to drill loads of holes in it for ventilation, and under no circumstances wear a mask, because the coughing fit caused by the irritation onn your lungs is crucial to kickstart the kyrpton crystals into reaction with the plutonium. failing this, buy a pack of 200 MARLBORO AND CHAIN SMOKE 'EM
i see where you have gone wrong. did you use a old toilet roll and some double sided sticky tape to hold it in place if you did not it will not work unless you do that and possibly some ct1 and expandy foam aswell
and don't forget to cover the whole thing with 600mm of fibreglass so as to cause major overheating
nah. that thick it might stop you falling through the ceiling as that is why it is installed in the first place. so you can't find the joists with your size 10's
[video=youtube;A2S7J_JBWds]http://www.youtube.com/watch?v=A2S7J_JBWds&feature=fvw[/video]
