Discuss Garage Receptacle Height? in the UK Electrical Forum area at ElectriciansForums.net
In the U.K. we don’t generally allow sockets (recepticals) where there are explosive gasses.
Or use intrinsically safe outlets and equipment (eg ATEX) where classification/ regulations permit?
I don't know about height, but the type of outlet/connector matters.
DIYer here. Can somebody tell me what the required height is for receptacles in a garage due to possible flammable vapors? Thanks
I need more information because it sounds like you have a class 1 division 1 environment especially if flammable vapors are present. You need to install them 18 inches to the bottom of the receptacle.
Actually its going to be a detached wood shop 40'x50', but I will be parking 2 vehicles on the other side of the shop. A friend mentioned since you are parking vehicles there is a potential risk of gasoline vapors say something leaked. So he said put them up high. I was just wondering how high do I have to put them in this case. The ones in my attached garage are at 28" from the bottom of the boxes. Thanks
28 inches should be fine. Good luck
Reply to Garage Receptacle Height? in the UK Electrical Forum area at ElectriciansForums.net
I ripped off the old cracked coverings on a wall to install new gyproc. I found in the wall an electrical single gang box (without the...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
