I think you might need to elaborate. Where are you measuring 56v and earth leakage?
Testing the outer casing to what?
What is this USB outlet, a charger or fixed accessory?
It's was charging a Fitbit watch but it doesn't matter what you charge. If you put a volt meter one end on the metal strap on the watch on charge and the other on a earthing point your get 56 Volts
Where did you get the charger from?
I've had it for years. But this isn't the only device I charged a metal torch and the torch casing also become live. I can feel the voltage it's enough for you to want to move your hand away. At the Weekend I will take it apart
Is this a 13A mains socket with USB outlet integrated into it? If so what brand?
