• Electrician Forum
    Welcome to Electrician Forum. We started out on April 22nd 2006 and used Electricians Forums as our brand name which is an unregistered trademark.
Dec 14, 2012
401
89
103
54
Kent
New gas boiler install. Previously no gas in dwelling, water is plastic. So no bonding presently.
No other work, boiler supply to use existing Electric Heater Circuit.
What certification should be used, It's not a new circuit, so not EIC. So just Minor Works?
No bonding required if gas main incomer is plastic or has an insulator and minor works for electrical connection
IMO the boiler should not be commissioned untill the gas service is bonded in this situation.
If it was me, I would defo fill in a MEIWC, but I'm trying to get another sparc to do one. But I can't find anything black and white on this.
Is the other sparks working for you if this is the case tell him that's what you want.
It's retrospective request, so easy to say no, unless something in regs I can point to, but it does seem to be upto the sparc
Will have to pass it bye then.
Do a minor works for connecting the new gas boiler and add some notes regarding the addition of the bonding.
Kent
Gas Bonding Certification
UK
Electrician Forum
Michaelwgroves,
diditrain,
