Not used then Kewtech ersion but a set from maplins instead. I find its makes linking out easier than connector block or similar.
Also good as you can null out a socket adaptor easy with the too
Thanks Lenny,
Gonna order me some as well !!
Look very easy to use, as opposed to the old connector block routine !!
Sav
The pic isn't very accurate, just to confirm you get 2 x long leads (size shown in pic) and 2 x short ones.
How tight are the clips? Are they going to make as good a connection as using connector block would?
Senet held a brecfast morning and a kewteck rep was their ive ordered a full test set ,set of 5 light mate adaptors ,jump leads ,lock off ,and an r1r2 adaptor, all for £65.00 just waiting to get it
Thought i'd get a set today as they look to have larger croc clips than the maplin versions, so might have a better contact.
PS.
Mr Test Meter you need to do something about your postage costs, got a set for 14.99 plus VAT including postage
my collage tutor used them(home made version)
at the time i had a fluke multitest which was random on continuity at best.
these just made it more random.
now ive a megger 1552 i may try it again...
after all some body always uses the last connector stip init!
