BenCos18
trying to find something to post about is always hard I guess but might as well share network stuff I guess this time haha
currently I have a ubiquiti edgerouter x and a 5 port poe switch with a old 8 port switch (eventually I should consolidate it all)
also has a u6 pro at the side that I need to mount eventually when I get round to it™.
then I have a old thin cilient machine at the side that I git from ebay a while ago (futro s920) that runs home assistant and a few addons that give me a dns level adblocker and other useful stuff like a password manager I recently installed).
I also have two lines I have ran up to the loft (one feeds my ads-b stuff I mentioned in my last post) and the other feeds a tenda poe powered poe switch I use to run my acars pi and also provide network to my other acars mini pc machine
I also have two esp32 lora boards mounted on the wall (the white devices with a screen) one is a tinygs ground station for receiving satellites that use 433 mhz signals and the other is a for picking up 433 devices I have (only one cheap weather station thing atm but eventually I want to get a few more at some point)
there's also some voice control stuff but I haven't done much with it in quite a while as the esp32 dev board I was using as the mic died
