Dec 4, 2024
Lichfield
Trainee Electrician
I have recently upgraded my hallway lighting to a two way system and it worked perfectly fine on my original ceiling lights. I have now replaced the original lights with new fittings and now having issues. Only one light will work at a time depending on the removal or changing of bulbs in the other light. I am extremely confused. Any help would be appreciated???
Is there a dimmerswitch in place .prob unlikely if in hallway
There’s no dimmer switch in place
It sounds like there wired in series which would be very odd if you just changed like for like.what type of lights are they is there a led driver in place ,is there 2 line and neutrals at first and 1 at second .did you alter any switches .you could send pictures if possible.maybe double check your sw wire and neutral connections are not loose
Also what type of lamps are they
I’ve triple checked wiring and all making solid connections in terminals. The two way switch definitely works as it was fine on the original light fittings. There are 2 line and neutral at the first lamp and 1 line and neutral at the second lamp. All switches are 2 way switches and worked on the original lights. The bulbs are LED dimmable bulbs at 4w. Each light fitting has 3 bulbs. Hope this helps
Are they mains voltage lamps or is there a led driver inside fitting
You could try removing lights and using a volt meter testing to make sure you have 240v from live to neutral ,240v from live to earth and 0v from neutral to earth .put them in connectors as they are connected currently .check it from both 2 way switchs and intermediate if you have
Could the bulbs be an issue by any chance, I’ve swapped them for higher wattage bulbs and they’re fine now?
Possibly but that was normally an issue with low voltage lamps where the transformer had a minimum wattage to work .ie a 20 va transformer wouldn't power a 10 watt lamp.but that's not the case with yours if everything is mains voltage .would need to really test the circuit in question with a mft to be sure .faulty neutrals can do funny things.a broken neutral can effectively become live thru a lamp for instance
It’s almost like there’s not enough power to the lights, and if I remove a bulb from either light, the other light will brighten.
Odd, can you post a video?
Each lamp should be receiving the same voltage regardless of removing 1 of them.only the current would decrease
.1 light dimming and 1 getting brighter might indicate a more serious fault somewhere else .you would need to really fully test the circuit .
Is this one of those complicated 2-way circuits where the 3 core passes thtrough the light fitting.... Maybe you've got the lights across the strappers. ?
Reactions: westward10
Ha.had a whole school corridor like that when I was an apprentice ,was only changing type of fitting .nightmare .couldn't work out why there was so many cables at lights in connectors .had to get the big boss man out
Lichfield
Trainee Electrician
Two way switch controlling two lights
Jxsand,
Jock from the north,
