My house has three external power outlets as far as I know.
Two have covers and the third doesn't.
As luck would have it, the one that doesn't have a cover isn't working now.
I don't know how long it's been this way. I don't think I ever used it.
The house is 28 years old.
There is a main power panel in the basement where there is an outdoor
outlet breaker. I tried resetting it but it didn't have any effect on the outlet.
Is there an easy way an amateur like me can get it working again?
It may be. that. because there is no cover it's been disconnected, have you opened it up?
Upvote 0
Thanks for your reply Eddie.
I haven't opened it up.
I would expect to see some rusty wires there. :)
If I did, should I turn off the external outlets on the main power panel first?
Always isolate any circuit before opening the accessory, just be aware though that the socket you intend to open isn't working that doesn't mean there's no power there, you must test the wires L-E L-N N-E before disconnecting.
Upvote 0
