Just been in the loft today and noticed our Aqualisa Visage Shower Pump located by the loft hatch (fitted originally by a plumber 16 years ago who wired it all and an Aqualisa Engineer 10yrs ago who had to replace the pump!) had two cables connected by what I presumed were choc blocks, wrapped in loads of insulating tape. That didn't look right so nipped to Screwfix and got a Connector Box. It looks like the white cable is fed from the airing cupboard because we gave up our immersion heater for a power source, so wired from the old Immersion Heater switch and a black cable that goes into the pump from the choc blocks.
Undoing all the tape I found the all wires secured in the choc blocks BUT the white cable was 4 core, with four cables coloured Black/Brown/Grey/Green/Yellow. The grey wire had been snipped with the copper exposed and not connected to anything!
What's the best thing to do, apart from getting hold of an Electrician pronto? I've switched off the Central Heating Circuit in the Consumer Unit and my short term plan is to leave it like that, pop the loft hatch back up and regroup in the morning?
I'm assuming that 4 core cable isn't correct or can I terminate that wire in another choc block and pop all the connections into said Connector Block - my preferred option is to get an Electrician to do it properly.....
