Just been in the loft today and noticed our Aqualisa Visage Shower Pump located by the loft hatch (fitted originally by a plumber 16 years ago who wired it all and an Aqualisa Engineer 10yrs ago who had to replace the pump!) had two cables connected by what I presumed were choc blocks, wrapped in loads of insulating tape. That didn't look right so nipped to Screwfix and got a Connector Box. It looks like the white cable is fed from the airing cupboard because we gave up our immersion heater for a power source, so wired from the old Immersion Heater switch and a black cable that goes into the pump from the choc blocks.
Undoing all the tape I found the all wires secured in the choc blocks BUT the white cable was 4 core, with four cables coloured Black/Brown/Grey/Green/Yellow. The grey wire had been snipped with the copper exposed and not connected to anything!
What's the best thing to do, apart from getting hold of an Electrician pronto? I've switched off the Central Heating Circuit in the Consumer Unit and my short term plan is to leave it like that, pop the loft hatch back up and regroup in the morning?
I'm assuming that 4 core cable isn't correct or can I terminate that wire in another choc block and pop all the connections into said Connector Block - my preferred option is to get an Electrician to do it properly.....
It should be connected even if it does nothing just fit a four way connector.
Is the 4 core cable safe to use, I assume so as it's been there 16 years!
Is it as simple as just reconnecting to a 4 way choc block and pop it all in the choc box?
Also what amp rating for the choc blocks and I suppose I better check the fuse, assuming that should be 3amp for the shower pump and they changed it when changing the switch? (nothing would surprise me!)
I shouldn't go looking!
I had turned off the "Central Heating" circuit at the Consumer Unit to work on it, it's still off and I've been in the airing cupboard and although the shower is dead (as it should be) the blue light on the boiler is on as is the Programmer - wouldn't they be wired into the Central Heating circuit?? Or is just the Immersion switch that now controls the shower?
Next....checked the switch controlling the shower and it doesn't appear to have a fuse and one of the screw fittings is half out - pic below, how is it fused, if at all. The white cable into the switch goes up through the ceiling and must be the 4 core cable.
It will only be fused back at the consumer unit. You can replace that Water Heater switch with a fuse spur.
The circuit that is on labelled "Central Heating" has a B16 mcb, so assume 16amp, so popping a fuse spur at 3amp would suffice?
Would the choc blocks also be 3amp.
Assuming the gas boiler, programmer and pumps running off the sockets circuit (again B16) is fine?
Try with a 3A fuse worst that can happen is the fuse will blow.
Replace the block connectors with these;
Tbh I'll get an Electrician to replace the switch, I'm ok with choc blocks and wagos for connections but not confident with switches.
I'll probably sort the connections in the loft tomorrow to get the shower up and running - my Mrs takes the view that it's worked for 16 years and not to touch anything and doesn't really get the safety angle!
The best maintenace of the property is if you learn how to maintain it I speak from experience.
And this forum and my father helped me resolve a similar issue. Not sure here they hide when you try and hire one.
Anyway if it was me I will buy a new pump and rewire it. It is not hard i have done it. Just make sure to read the manual watch tutorials and do continuinity tests if not sure. But on mine the manual had a diagram and everything it was great.
Ordinarily and if I were 10 years younger, with better eyesight, there would be some truth to what you are saying.
There is no need to replace the pump (£400+ for the equivalent) If the cable feeding the pump was 3 core, then I'd be semi confident, but as this cable is 4 core, I currently have no idea if it is connected in the switch or not, but I'm assuming not. I could handle the connection in the loft as I'd just terminate the grey wire in a connector box, as suggested, but wouldn't have the first idea how to handle the 4 core at the switch end which also needs replacing. It needs an FCU (imho) as it's currently relying on a 16amp mcb in the CU, when the pump states connected to a 3amp fuse.
I'm also not agile enough to change the cable to 3 core, if that's needed, by chasing it through our loft space!
At the end of the day, I'm self employed in another industry and I appreciate my customers relying on my expertise, when they could do it themselves, so I value and will pay for the privilege of a specialist especially when it comes to electrics. It's a question as to where I draw the line, this isn't simple imho and I have no inclination to educate myself by spending a lot of money on a pump that I don't need currently!
Ok let us know if the specialist you will hire does the job to your satisfaction
Job completed to my satisfaction, in fact he noticed something else that wasn't ideal and fixed that and still charged the quoted price.
It would have cost me some money for materials, wagos, junction box, switch, plus I'd only do it with the right tools, so would have invested in a proper wire stripper. That would have been around 20% of the cost for the electrician to do it, more than happy to pay 80% more for someone to do it properly and you can't put a price on piece of mind imho.
Just to add that the grey wire was not connected in the switch and snipped in the same way as the other connection (as per photo) Both grey wires have now been terminated correctly within both the switch and connection in the loft.
