P
pushrod
A person takes a new 60W incandescent bulb, designed for domestic use, out of its box and use a ohmmeter to check if the filament is intact. Estimate the reading on the meter.
Don't post your answer just say "done" and when a few people have had a go or an hour or two has passed i'll put the answer up and explain if needed.
Mmmmh moved from electrical courses to "chit chat", hardly the target audience - wasn't it just a few days ago that someone was asking for questions :confused:
Anyway the answer as promised
A good place to start is with P=I*V and R=V/I ... which might, or might not, have got you to R=V²/P
...and the answer should be in the region of 90Ω.
Sorry for my lack of focus on my thread, point taken. I've had a load of work thrown my way this week and I haven't had the amount of time that is needed to concentrate on this matter. Apologies to all that have been kind enough to give their help and time on the 2391. Eg I left home this morning at 0645, just got home now at 21:15 and the first thing I did was look at the forum so please give me the rest of this week to be able to earn the money needed to pay for Xmas presents, thank you. As you all know, studying for this can not be done by just giving five or ten minutes here and there. Please post your questions, they will be answered by me and others that are in the same boat. Again thank you, I have nothing but respect for the forum members and your comment has not been taken personally Pushrod, it was an observation and rightfully so. Back on track by Sunday but there are others that need your guidance.
somewherer between the 100 omegas and the bit of solder drip on my AVO7
the cold resistance will be lower than the calculated for tungsten anyhow
i've been drinking again so i better lay off the calculations
Spot on! Resistance is approx 880 ohms when connected but massively lower when cold which is what it was when taken out of the box.:)
he measured it with a ohmmeter
No problem Paul - i just thought it was a good example of one of those horrible questions where you think "yep i can do that" and you then relax and don't think quite carefully enough. A bit like the scenario questions at the end of 2391 where it is all to easy to relax a bit and forget to think. I saw one today where the question asked "how would you do an insulation resistance test on circuit 3" .It was all to easy just to go onto autopilot and describe in detail how to do an IR test, but 3 of the 7 marks for it were for removing vulnerable equipment shown in the diagram that were on the circuit!
I reckon it pays to think "now why could this not be straight forward, what is special about this (circuit)?" And to read that scenario several times, highlighting any technical info.
how did you get to 90 ohms?
To be honest it is just one of the useless bits of knowledge that i carry around in my head - like the tungsten is a few thousand degrees celcius when on - the resistance increases approx tenfold as it heats up. I just wanted to use it to illustrate a point about questions, and any answer that "estimated" much less than the hot value would have been good. There is nothing there that is hard, it is just the way it is asked.
good job it does increase or it would pull over 2.5A at 90ohms and we could not fit many of them on a 6A MCB
pushrod,
telectrix,
