Go on the UKPRA website and report it. I got a call in the really cold spell to a property owned by a millionaire, he was having problems with a circuit tripping out and loosing power to his electric heaters. I went and had a look at the problem. Found old Wylex fuse board feeding 2.5mm T&E on a 15a fuse, to a plastic junction box screwed to the side of the house, then 4 more 2.5's coming out of the box and going into 3 adjoining houses suppling 3Kw heaters. I told him that the circuit was overloaded, and the cable size was under rated amongst other defects. Looked into it further, and found the wylex board was supplied from a 3ph supply head into a 3ph dist board. There were no meters on the 3ph supply, and it is fairly new. There is only one meter which supplies the main house, 2 other houses, several outbuildings, and a very large workshop are being supplied from this unmetered supply. Made the call and waiting for the fireworks to start. Didnt give him a price to upgrade the circuit either.
Cheers........Howard
