S
SirKit Breaker
In between going on here, making the Sunday dinner and downing a few tins, i am trying to revise for the 2391 exams next month.
I keep finding myself drifting into stupidity, i can now recite all the practical test procedures from start to finish. Its like having one of those annoying songs in your head that you can't stop singing to yourself over and over again.
I haven't read the paper for a few days, i just pick up GN3.........have i lost it or what?
Well if you're starting to do things off the top of your head, start focusing on the other things. For example, keep sketching the earth fault loop return paths till you master it
:p
and sketch the route to the pub for when you come out of the exam
IP codes, and working resistance figures . apart from that it sounds like another pass :)
I'm Ok with the IP codes both wet and dry. the resistance calcs i am trying to convert to pints of lager, might get my head round it then, i know it is straight forward but its like rocket science to me at the moment. When i did all my other exams i skipped the maths ones and made sure i got the rest of it sorted out, but this one is likely to throw a good few points in on the maths side of things.
I will get there, the more i read it, the more the penny starts to drop.
Cheers.......Howard
I found keeping an osg in the loo and drip feeding info to your head while you, well you know, helps get extra stuff into the grey bits. When's the exam?
SirKit Breaker,
irishsailor,
