It seems there is either some sort of problem with wire insulation (the house was made a long time ago and some parts of the electrical circuit havent been changed) or with the diferential switch.
And since i cannot fix either problem by myself, Ill call an electrician over to see whats going on...
Ill keep you posted!
Please do, it's always interesting to find out what the cause was of a problem. My money's on cable insulation deteriorated or faulty appliance/fitting somewhere leaking to earth.
Yes Chappers it woukd be interesting to find out whats happening, a 300mA RCBO and a 'C' rating at that!
I am gonna go with 'switch on surges' for the kit plugged in. Mains filter capacitors charging up with a high leakage to earth.
If there is a 300mA RCBO fitted there must be an expect high leakage on the system in general. Add this to the kit surges and pop?????
Somethings a miss - extension keep us posted!
Well, the fake ground was the problem. It seems current exiting the appliances was going through both null and the fake ground. So when I plugged the computer to a real grounded socket, the fake ground got connected to the real ground and the current went from null to the earth.
When you say null, do you mean neutral? As in the neutral of the socket was connected to earth?
Yes. Its an old house and this connection -neutral-ground- has been done in more than one socket. So, the electrician said he is going to remove that switch.
But Ive got a new question: what will happen when i plug in the antenna? Is there a chance that the current leaking throught it might destroy the tv?
