Megger MIT330 testing kit
Used to have MTK320 kit.
Brilliant testers, although the EL tester is quite slow on non trip.
And the auto RCD test is a great idea.
If you can afford them then go for it.
I dont think you will be disappointed.
What you also need to consider is that you will be without a tester if/when it needs to go in for calibration or repair if you purchase an all in one unit.
Must admit, i use a robin test kit which is great but i am considering moving to an all in one and keeping the robins for back up.
Agreed, I also have old kit as emergency backup.
