Hi guys i'm on my 2nd year finishing 2330 level 2 going onto level 3.
Just wandering what type of Multimeter should i buy just for me to complete this course as money is a problem at the moment.
would appreciate your knowledge.
Rudeboy500
they not supplying the gear? you would need continuity tester and insulation resistance tester megger MIT 300 but if you have the money i would go for a MFT1552 all in one
hope this helps mate
Does anyone actually use a multi-meter on a daily basis?
I've got one, and I cannot recall the last time I used it. I've got a Fluke Voltage/continuity tester, and a Multi-function for final testing, but have no use at all for the multi-meter.
Alan.
Use a multi meter very regularly as I do a bit of fault finding on various BMS systems.
Me to I would not be without my fluke plus it does not trip the RCD when testing domestics unlike my voltage test and I always forget so when I reference to earth I hear the RCD click (damm) also my multimeter is great on alarms.
So I have
1. Megger 1553
2. Fluke multimeter
3.Martindale voltage tester
4. Amp probe
5. led voltage tester
HI.
I came out of my time in 2000 and the electricians i worked with all had steniel combi checks which we all remember, in 2000 I bought a fluke t5-1000 multimeter, I have just had it calibrated after 11 years and believe it it never needed adjusting, fluke test equipmement is the best even though I have a megger mft1553 and cant fault this either I also have a fluke 25 its old but works very well.
For day to day you can't beat a fluke T-5 1000/600 ideal piece of kit!! Couldn't be without mine
Multimeter for alarms and electronics repairs (PC's, SAT boxes etc). Have to say it gets used a lot more than my clamp meter! MFT1553 for domestic testing though.
hi guy iv got a fluke 1651 multi tester 17th ed acceptable but current calibration has run out but still works fine an a seaward pat prime 50 like new still has wrap on screen comes with stickers and test book. any idea how much i could get for these.
only selling as dont use the and my elecsa is due to run out end of the month
