K
Knobhead
Is it possible to add an alarm
To call maintenance if the mccb tripped
It’s a bit late by then, the problem has to be stopped before it starts.
Quote the plant manager “did you know the main breaker’s tripped again?” Me “yes the fu**ing kettles stopped boiling and it’s bl**dy dark in here!”
Discrimination and trip settings are a nightmare when you get to 400A+ breakers, as Baldsparkies obviously knows. Both time and current are adjustable so it’s easy to alter one setting on the local breaker and move the problem one step up the ladder.
