B
Benspark
Hi im a quallified part p registered electrician, i have recently done some work in a kitchen where i have altered a cooker and lighting circuit. I wanted to provide RCD protection by means of individual Rcbo's, problem is the board is an older Wylex board the breakers are NSB06 there older style to the new ones with white switches. Does anyone know if i can get an Rcbo to fit this board?
I would be very gratefull for some advice
Ben
No worries.
Your local wholesaler should have them or be able to get them for you.
Good luck.
Im still non the wiser, to be honest. Also how do i view this thread and its replies, i just had to go back god knows how many times, still learning the ropes lol
If you click on settings it will show any thread you have posted in. Click on the title and you can view all again or click on the small double arrow by the name of the person who last posted will take you to the last post. Best advice on the RCBO would be take to you local wholesale co and ask if they can help. I have been asking my local lot loads of questions, the only way to learn. Good luck
The search results i linked to has rcbo's that should fit.
Your MCB is a 60898 which is current.
I checked this out, and on the search page it links to an electricians forum page....
this is dangerous, a lot of people really don't understand the internet....
this could cause an infinite loop and cause the internet to implode!
and yeah, a Wylex RCBO will fit... alot of them are C type though, so you may want to check your disconnection times (or ensure you do get a B type) and you'll probably have to struggle moving the neutrals about to get it in
