La Poste
Greetings all.
My neighbour has just had a garage built in the shape of an old barn.
We live in the sticks and I guess the only way the architect could get it through planning was to make it this way.
It's in keeping with the surrounding area.
As he is my next door neighbour he has asked me to do the electrics.
The supply is a 2.5mm SWA buried underground.
The system is a TN-S with the transformer on a pole in the field out back.
I will have a quick look at it later but I have a couple of small queries if anyone can enlighten me.
As the supply is SWA which means it is earthed in a metal housing does it need to be RCD protected.
I don't think it does, I am thinking of a distribution circuit you know like they supply street lights with and a 5 second disconnection time.
As the supply is TN-S from an underground supply cable I don't think exporting an earth from the main house will be a problem.
I could TT it and would probably get low results for EFLI but I would prefer to keep the distributors earth.
Can anyone see any problems with exporting a TN-S earth?
The other question is I want to encase all the cables in black galvanized metal conduit to give it a more pleasant look but I am little concerned about the sockets.
What would members consider to be the best and most attractive sockets and switches to put on.
They would be metal surface mounted supplied by cables in black enameled conduit.
Has anyone any recommendations?
I will take some pictures in due time but I wondered if anyone has ever done a job like this.
Many thanks.
Many thanks.
