If the connector block was in some kind of container/box with cord grips and the connectors were the type that had little metal flap under the screw to the screw is not tightening directly onto the cables nothing at all. I agree connectors are the simplest quickest way of doing this but there are just too many regs against them now.
And one of these regs would be .................................
no regs against them. just how and where they can and can't be used.
It may not be too long before most accessories are fitted with lever or clip crimp connectors. Already have them in 2D fittings.
sorry there's no regs directly against them however they must be enclosed reg 526.9 and also the problem with using multi-wire, fine wire cables with solid core cables directly under a screw reg 526.8 I do apologise I assumed you meant using connectors with insulating type.
so that would be bunched together then wouldn`t it? Have you looked at a connector block recently?....THERE ARE 2 WAYS IN.....
very true however with Flex as it is a multi wire/fine wire cable unless the connector is a suitable type i.e the screw does not clamp directly onto the cable it is still not permitted the last time I looked most of the connectors we still get from the wholesalers have the screws in direct contact with the cables.
lol ok in that case as long as the connectors are within a box yes you can use them I think I will give in at this point I think I lost this one:tounge_smile:
e the cable guard plates and never give trouble.i'd call it a draw. the terminal strips i use ( from electric center hav
bloody laptop having that stupid pad where i rest my elbow.
