P
pencilpusher
My "main switch" is an isolator fitted in the meter cupboard by the DNO. The installation is 10 years old. This appears to be single pole. Maybe it does isolate both poles but it is very small. Is this right?
Thanks PP
Wouldn't have thought the DNO would fit an SP main switch......any chance of a description/pic?
what cables go in/out of the isolator?
evening lads..how do i go about posting a thread on here....im new to the site. many thanks
How do you know that it is single pole, have you put your test equiptment on it. I have a wylex one that has an image on it depicting that it is single pole but it is definately double
Photo attached. The switch is in the middle of the isolator so I suspect it's DP. Maybe a silly question but I am still learning and want to know everything!! Thanks. PP
welcome to the forum....look for "post new thread" at the top left of the page mate....click on that and it will let you post on here mate......
Enter which ever forum you want to start a thread in & at the top, on the left you will see a highlighted blue bar "post new thread"
Click on that and away you go.:pimp:
double pole. can clearly see L and N on the pic.
I could see that but was not sure what the switch, switched. Thanks all. PP
EDIT: As usual, there is no BSEN number shown at all on the sides etc etc. What do you think the BSEN should be for an isolator which I believe is different from a CU main switch?
pencilpusher,
Guest123,
