B
brizospark
In the wholesalers today the manager said he had seen an attachment for a battery drill that will thread 20 / 25mm steel conduit
Has anyone seen these or know where to get hold of one?
Must be a big battery drill then as once taps/dies start to "bite".....hell of a lot of torque to run em.........
That sounds like a dangerous recipe for an otherwise simple task to go very wrong!
can you get a battery drill that goes half a turn clockwise, then half a turn anti-clockwise and so on?
Electric conduit threaders are magic but as has been said there is a fair torque in them.Worse if the threader isn't sharp
Die stocks!...with a bit of effort behind em..and theres tecknique of course..as above half a turn on then half a turn off to break the cutting.......and a good cutting paste/fat helps....
Most battery drills do have a switch on them that reverses the direction
i know,but you need an auto reverse forwards/back/fowward/back. ....... can't beat a stock and die. not like you're threading 2 ft. of it.
laziness,same as those electric screwdrivers and screw bits for drills,use ya bloody hands..
they seem a bit dangerous to me,as most know sometimes dies can stick and bite on the pipe,these things could could snap your arms if they stick.
Would save some considerable time if something like that was introduced, to be fair though it takes a couple of minutes to put a thread onto a bit of galv, also gives you a bit of a workout
brizospark,
Admin,
