S
sambotc
Am I correct in saying that if the incoming supply is copper then it would come under main equipotential bonding to a service, whereas if the supply is in plastic which then changes to copper inside the property, therefore unable to introduce a fault into the property, it comes under supplementery bonding which could then be classified as or not extraneous so could not actually be required?
